MS Word and Print Document
What is the shortcut key of print preview & what's the keyboard shortcut key for Print document ?
Best Answer by Raewyn walta
Answered By 0 points N/A #125316
Hello Rabbi,
Here I have the solution. After finishing you work on Microsoft Office before go for print you may preview it.
Keyboard key for print previews you can use CTRL+F2. ALT+CTRL+I is also used for print preview.
And for go to print the final document you can use a keyboard key.
Press on keyboard CTRL+P. Another shortcut for print on Microsoft Office: press CTRL+SHIFT+F12 at a same time.
If you need more shortcuts visit this link
If it helps you, I will be so happy.
Thank you.
Answered By 0 points N/A #125317
Hi Rabbi,
To control preview,  the short cut key is ctrl+F2 and the shortcut for Print = Ctrl+P.
