Ms. Word Error Messages on various commands
Follow the steps and check if that helps:
1. Go to the location C:Program FileMicrosoft OfficeOffice 12Winword.exe
(If you are using a 64bit machine, then you would have to go to C:Program files x86Microsoft OfficeOffice 12Winword.exe)
2. Right click on Winword.exe and click onProperties and then click on Compatibility tab. Check if you have any check mark in any of the compatibility mode options. Make sure you also click on the option"change settings for all users" tab at the bottom of the same screen and look for similar check boxes in the window.
3. Uncheck the option Run as Administrator option is you have it checked.
4. If you see any check boxes in the compatibility mode options,uncheck all the boxes and click on Apply and OK.
5. Try to open Word now and check.
I’m not sure if there is a list of error codes and or error messages that can be generated specifically from Microsoft Office Word but there are available errors codes and error messages that you can access for your own reference for Windows Installer processes in Microsoft Office 2000 products.
Here are some of the error codes and their specific descriptions from the list in this order: error code, value, and description.
For the complete list of error codes and error messages, you may visit List of Error Codes and Error Messages
