MS word office has stopped working……need help
i am currently encountering this error when i open a previously saved file on MS word office 2007.
I have already tried uninstalling the program and have reinstalled it again, but i am still encountering the same problem.
Any advice or suggestions on this problem is greatly appreciated. thank you
Microsoft Windows
Microsoft Office Word has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Close program
Windows cannot open the file "" . If the file is stored on your computer, there may be a problem with your hardware. If the file is stored on the network, there may be a problem with the network connection. If you can copy the file, try saving the file in another location and opening it there.
OK
