MS Word Document Save Location change
Can we change document save location?
Write down the steps on how to change document save location.
Best Answer by Joseph09
Answered By 5 points N/A #125297
In Microsoft Word 2007 to change the default location of “Save As”:
  • Simply click on the MS Office logo that is located on the top left of the screen.
  • After clicking on the logo a drop down box will appear and at the bottom there is an option “Word Options”, click on this option.
  • After clicking on the option “Word Options” a pop-up menu will appear.
  • Navigate to the Save section by clicking on “Save” from the list of options on the left hand side of the pop-up menu.
  • In this page there will be a portion where you can change the default “Save As” location.
Answered By 0 points N/A #125299
When using Microsoft Word and you had saved a document on a different location, you can change the location of where you have saved your document.
The procedure is simply click Save As and then change location from the dialog box.
Click and change the name on the dialog box and click on Save.
