MS Work facing error while opening any file or document
I have been using MS Work perfectly well, however something happened recently and I cannot open any file or document and I receive this error message, does anyone have an idea what the problem could be?
Microsoft Works
Microsoft Works cannot access one or more files it needs to run. The files may have been renamed, deleted, or
moved. Try reinstalling Microsoft Works, and then starting again.
        OK
