Miley Adams
Posted on - 10/27/2011
I am receiving error when I try to print from Microsoft Works. The error message I am receiving is: Out of Memory. The program can continue from running but I could not print anything. If you know how to deal with this error, please let me know. Thank you!
Ms Works Out of Memory Error
Hi…
 This is an error occurs when there is a problem with the printer that installed. When the printer does not install well, or it has bad configurations this problem will occur.
There are few methods that you can apply to prevent from this problem.
First method that you can do is reinstalled or changes the printer software. You can re install the printer or update or install the latest version of the printer software. That will stop the problem that you faced.
Second method is to install the printer as a default printer.
Is your operating system is Window environment you can do it like this.
First Click Start and go to the Printer and Faxes.Then you can select the printer you use right click on it and set is as default.
Then you can do your works well.
Thank you…….
Does this happen when you’re trying preview or print a spreadsheet file in Microsoft Works? If this is the case then this is caused by a problem with the driver of the printer installed on your computer. Try using a different printer driver software or using a more updated version of the driver. Kindly check with the manufacturer of your printer or check their website for this information. You can also configure the printer drive installed as the default printer. Do this by going to Printer and Faxes from the Start menu. Find the printer you’re using, right click on it and choose Set as Default Printer. Then try and see if you print with Microsoft Works this time.
Thank you. Hope this helps.
Clair june
