Msascui.exe application error
Hello, what are the ways to solve the issues caused by msascui.exe application error? It will be of great help if it is answered.
Hi, msascui.exe is a digitally signed file that exists in the c folder of the system, and it is from Microsoft. A digital signature file is the one that guarantees us the content of the message will not be changed during its transmit. It is one of the parts of windows defender antispyware from Microsoft.
These type of folders holds the responsibility of undergoing the scans for spyware. Spyware is one of the types of malware but little different to work done by it. While coming to the causes, it may be formed due to the low performance of the system and also due to some data loss in a system.
Some other causes could be it may be attacked by viruses or got corrupted. Then the system displays an error like windows defender cant work properly and protects the system.
Solutions to fix the issue:
1: Open windows task manager, then click on the processes tab, click on msascui.exe, and terminate it. Now go to my computer click on program files, then windows defender and delete it This will clear the issue and also increases the performance of pc.
2: Search for system restore, then enter the administrator password and follow the process of wizard manager. Then restore the backup image of the computer. If this doesn’t work, go to step 3.
3: Search for cmd and then press control+shift and press enter. Now, click yes on the prompt appeared on the screen There appears a blank screen type sfc/scannow and click enter. It completes the process. If this doesn’t work, check for windows updates and install them and restart the system. I hope this works for you. If facing any issue, feel free to write to us.
