The msascui.exe application error occuurred
Has anyone experienced the msascui.exe error? I do not understand where it is coming from but I took a screen shot to show the experts here and maybe I can finally solve it.
MSASCui.exe – Application Error
The instruction at 0x10001186 referenced memory at 0x10001186. The memory could not be written.
Click on OK to terminate the program
OK
Answered By points N/A #177755
MSASCui.exe is part of Microsoft Windows Protector Anti Spyware program that is pre-installed on the Vista Operating Systems. MSASCui.exe is the Defender's User Interface application
Located in C:Program FilesWindows Defender folder.  To remove your error try this:
1. First of all Open Windows Defender
2. Then click on the TOOLS icon
3. Click on Options
4. And now Remove the check-mark for Automatically scan my computer.
Beside this also you can try: Go Run> type in >> 'msconfig” << Click the Startup tab>>
Then Remove the check-mark Windows Defender
If wanted more information on using 'msconfig” visit below site.
In this site you will get step-by-step instructions on how to use MSCONFIG and choose your version of Windows.
For Windows 7
For Windows Vista
For Windows XP
Also you can use a registry cleaner software to solve this problem because a registry cleaner can eliminate errors in your files.
