Msde para windows7 64 bits Home Premium?
I am having problem with my laptop, MSDE is not running or I believe it wasn’t. There is some software I need but can’t complete installing because MSDE is required. But my laptop always says incompatible to my windows version. What does this mean? That MSDE for windows7 64 bits in home premium would not work? How about for 32bits, or windows 7 ultimate and windows 7 professional?
Answered By 0 points N/A #162799
Hello Ann Jolin,
You must install that version of MSDE that is compatible with both your system’s hardware and Operating System as well. If you are still facing problems after having the compatible versions then try running the setup file in compatibility mode. Just follow these steps;
·         Right click on the setup file and choose Properties.
·         Under Compatibility tab check the option “Run this program in compatibility mode for” and then choose your OS version.
·         Click Apply and then OK.
Try installing now. If the problem still occurs then try running the setup file from an Administrator account.
