Hello. While doing some research, I saw some error codes in Hex format. Something like 0x800 and Facility 7 = Windows. As it literally pertaining to error code 0x800….. in Windows 7. My question is does anybody here knows or heard about the Microsoft Developer Network (MSDN) or document from MS TechNet that lists the entire Hex error codes configuration of Windows computer. Can someone please bear with me as I am very noob in terms of computers? Thank you.
MSDN or TechNet Documentation of Hex Error Codes
I will suggest that you try the following workarounds to fix the problem;
You will need to contact MS support and explain to them the problem; they might help you fix the problem.
You will need to try starting the computer in safe mode and see if that solves the problem.
You can also try re-Installing the windows version that you are using and see if that fixes the problem. Change the boot order in the BIOS so that the computer boots from the CD ROM.
If the problem persists, then it may be possible that the copy of the windows operating system that you are using is not genuine and therefore you will need to get a genuine copy and install it.
-Thompson Locker
