Peng Hardin
10 points
Posted on - 01/30/2013
MSI Error 1935 When Installing Dynamics NAV 5.0SP1 on Windows 7, you may get the following error message, when you need to install “Dynamics NAV 5.0SP1” on a Windows 7 system:
Microsoft Dynamics NAV 5.0 SP1 CSIDE Client Install…
Error 1935.An error occurred during the installation of
assembly components
{38CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}.
HRESULT: 0x800736CC
OK
This error occurs when a .msi file tries to install many policy files on a computer running the .NET framework 2.0
The supported hotfix is available from Microsoft.
You can call Microsoft support team through the list provided here.
Error 1935 caused by the installation of Dynamics NAV 5.0SP1 on Windows 7 with .NET Framework can also be caused by anti viruses like.
You can disable the antivirus during the installation to enable the blocked files to be installed safely.
