Is MSI U120 Wind Netbook compatible to view in sunlight?Help
Asked By 100 points N/A Posted on -
Hi everyone,
I need your advice, my friend is selling his MSI U120 Win Netbook as I can't afford to buy a new netbook thinking to buy it from my friend but I have few doubts that should I buy this Wind netbook or not. I know its specs are quite good but will it boot up quickly and what about the sunlight view? Can we use the Netbook in sunlight with nice viewable screen or not as I'll be using it while traveling too.
Answered By 0 points N/A #189304
Hello Margarete
MSI U120 Win Netbook is a 2009 vintage netbook. It is good, but it cannot be upgraded at all, as it uses DDR2 Ram which has been almost phased out. Since RAM cannot updated, neither can the Operating System. So you will pretty much be stuck in 2009. Booting faster will depend a lot on how many programs are installed etc. Regarding sunlight, the display is not having any special feature to cater for it, so you can safely assume, it will be difficult to use it in sunlight despite of the matte screen. If I am to be straightforward, I would dissuade you from buying this netbook.
