MSMQ Installation Error: Not All Features Successfully Changed
I'm trying to install the MSMQ (Microsoft Message Queue Service) in Windows Vista, but an error message pops, "An error has occurred. Not all of the features were successfully changed."
I've tried to reinstall it a couple of times, but the same problem again. How I can fix this problem?
Answered By 5 points N/A #119027
You can use the “System Update Readiness Tool that can be found here. You can also use the SFC.exe or the “System File Checker” tool to know the root of the problem and then be able to replace that file. To perform this, follow the guide below.
  1. Run the command prompt as Administrator, click start > “All Programs” locate accessories right click it and then select Run as administrator. If you are asked for an Administrator password, then just fill it out with your password on your account.
  2. Type, sfc /scannow and press “Enter”
This scan will go through all protected system files and if any error is found in any incompatible versions, it will be automatically replaced. You can go to this link for more guides regarding this issue.
