Ronal Jober
Posted on - 11/11/2011
Hi Guys! Last Time I’ve received a notification from MSN that I need to change my e-mail address to continue using signing into the windows Live ™ Messenger Service. Does it really need to change my e-mail address? I’ve using my email address for a long time that’s why I don’t want to change it. Is there a possible way to by pass this error? Thanks.
Windows Liveâ„¢ Messenger Service Staff <messenger@microsoft.com
Windows Live ™ Messenger Servi… (Offline)
Windows Live â„¢ Messenger Service Staff is not in your contact list. Add to contact list.
Error :
Windows Live(TM) Messenger Service Staff says:
*Important service announcement: As part of a recent system enhancement, we need you to change your e-mail address to continue signing in to the Windows Live(TM) Messenger Service.
To ensure that your access is not blocked and to learn more, go to https://support.microsoft.com/en-us;
Jackman
MSN Change old email message
Select go the hold down the Alt key, click to add an email account that is your account, under the email address add you address by typing it. Type your password, add your name under the display name box. The ensure you check the automatic determine login. Manually configure the email account's server setting should be checked then click next check that the Imap is selected as your incoming mail server. Under incoming server enter imap.your website's account.com for example imap.gmail.com. On the outgoing type smtp.gmail.com and check the SSL under the outgoing server. When finished click ok. You are done.
