Msoffice Plug-in error while saving file
Hi trouble shooter,
I downloaded the trial version to explore Wordfast Pro in Mac. The problem triggered while saving translated files and it leaves the error message ‘error while saving file’. Why I am not able to save a file? Is this a bug? And also I tried to re-install it several times, but the error persists. Do I need to but the license for Wordfast? Help please.
Error while saving file.
java.lang.IndexOutOfBoundsException: Index 2, Size: 2
Answered By 590495 points N/A #193464
Check again if you meet all the requirements of Wordfast Pro. For Wordfast Pro 3, it supports Microsoft Windows XP and higher, Mac OS X 10.5 Leopard and higher, and Linux. Since you are using Mac OS X, make sure you are running Mac OS X 10.5 Leopard and later.
In case you are running an older version of Mac OS X like Mac OS X 10.4 Tiger and earlier, you need to use the 3.1.5 version of Wordfast Pro. To download the latest version as well as Wordfast Pro 3.1.5, visit Download Wordfast Pro for Windows, Mac, and Linux. You can find the download link for Wordfast Pro 3.1.5 under Mac section.
In case another problem appears after installing either Wordfast Pro 3.3.0 or Wordfast Pro 3.1.5, try updating your operating system. Click on the Apple menu and select Software Update. Install the updates on the next screen and restart your computer to finish the update. In case you are prompted, just enter your administrator username and password to continue.
