MSoft decline to learn it (from Mac OSX)
Hello
It updated all right then got a handful extra update however after a half hour with 4 -5 "reboots" it appeared ready to go.Â
But I required a VST host to make use of a few Windows only plug-ins.
I set up the eLicenser which had to act its own updates…as well as to my VMware USB menu showed all the dongles capped in the Mac.Â
Then I incited Wavelab 7 but then another Red Crossed showed saying it can’t get the WMVCORE.dll file.Â
Then I downloaded only the .dll file, and copied it in the registry and in the Wavelab file, that threw away the initial error message just to show a fresh more cryptic one:
I'll make an effort to download WMPlayer at present in case it sets up another voodoo type files Wavelab requires…Â
But MSoft decline to learn it (from Mac OSX): aim the Core OS to launch by itself with no reliance on "accessory" plans like IExplorer as well as now I locate WinMplayer.Â
I need a solution about all of this. Please give me a solution.
Thanks a lot.
