Msvcp100 Dll Missing Windows 10
When I try to launch a game or Origin, in particular, I get an error message msvcp100 dll missing windows 10 and the game or Origin crashes. How do I get past this? I need to start playing my games as soon as possible.
Answered By 0 points N/A #322941
The msvcp100.dll file is associated with Microsoft Visual C++. A lot of games are based on Visual C++ and therefore, whenever you launch a game, you are getting this error.
The first thing you need to check is the version of Visual C++ that in installed on your system. If this is not the latest version, I suggest you upgrade it to the latest version available. If this is not the problem, you can download msvcp100.dll from the internet and place it in the Systems folder of your computer. This should solve your problem. If you are reluctant to do so, just reinstall the entire Visual C++. This should solve the problem too
