A couple of days ago I downloaded TDACfg.exe. It downloaded successfully but when I try to install it setup I always receive this error message. You can see in the below attached image.
How I can make it to come into work. If somebody have an idea please share with me. Thanks
TDACfg.exe – system Error
The program can’t start because MSVCR100.dll is missing from your computer. Try reinstalling the program to fix this problem.
Hey,
Yes even now you can run your program successfully because as you have stated that your system is showing a message that msvcr100dll file is missing.
To solve the issue what you need to do is just download msvcr100dll that is missing and install it.
Hope this will a lot helpful in your case.
Thanks and Regards
Gillam Janetj
Hello Mr. Colleen,
Dynamic Link Library (.dll) is a very important application module to run programs. In your case msvcr100.dll is required to install the TDACfg.exe. Click here Download msvcr100.dll or Go here to download the msvcr100.dll file.
Now copy the msvcr100.dll file and paste it into the system directory which is :
C:WindowsSystem32
After performing the above action restart your PC and install the software.
Hope this helps.
Best regards.
