MudBox MAC OS X Lion restore windows problem
Hello there,
While Autodesk was loading this error appeared. It seems like I have to restore my Windows. This is a bit unexpected and I don’t want to restore my Windows. Does anyone have any idea why I have this error ? Why is asking to System Restore ?
Thank you experts !
Restore Windows
The application ‘Mudbox’ was forced to quit while trying to restore its windows. Do you want to try to restore its windows again?
Answered By points N/A #178571
Mudbox is really an awesome product of Autodesk. You’re trying to run it under Mac OS X Lion. This isn’t supported. Mudbox 2012 doesn’t support OS X Lion. You can check its system requirements from Mudbox 2012 System Requirements.
So, if you wish to run Mudbox on your system, you might consider different version of your Mac or use any other OSs that allows installing Mudbox, for example, Windows. Learn how to install Windows in Mac.
