I would like to facilitate upgrade in a learning school. I want to know more about HP Zvr. What do you mean by Anti-glare? What is the purpose of this? What is also the meaning and how useful is it Holography? What do you mean 16:9 aspect ratio? What is 4k and 5k display monitor? What do you mean by Oculus Rift? How much will it cost to buy a set of this desktop computer? Will it work to all software or application that we can buy or the 3D will require also 3D software that are affiliate and or converted? Please help. Thank you!
A multi-dimension e-learning experience from HP virtual reality
HP Zvr:
HP Zvr Virtual Reality Display: It Expands Computer Monitor Portfolio With Ultra High-Definition and Curved Display. We can Rotate, manipulate and navigate 3D images from the 23.6-inch diagonal interactive display. The HP Zvr will change how users think, work, and create with virtual-holographic 3D images.
Anti-glare:
Anti-glare screen is a clear panel placed over monitor screen that is used to reduce the glare of the screen from light sources. Anti-glare screen is not required unless you work on your computer in proximity to a window that is exposed to sunlight.
Holographic display:
Holographic display is a special kind of display technology that has a special ability to provide four eye functions such as Binocular disparity, Motion parallax, Accommodation, Convergence.
16:9 Aspect ratios:
16:9= 42:32 is a ratio with width 19 units and height 9 units. It is the international standard format for HDTV, full HD, non-HD digital television and analog wide screen television.
4K and 5K monitors:
4K monitors are Ultra HD monitor refers to 3840X2160 pixels. It refers to the approximately 4000 pixel wide display. And four times the overall pixel count, with the same 16:9 aspect ratio.
5K monitors are Ultra Sharp 27 Ultra HD monitor refers to 5120×2880 Ultra HD resolutions.
Oculus Rift:
The Oculus Rift is a new virtual reality headset that lets players step inside their favorite games and virtual worlds.
