Multi-tasking of Samsung Galaxy Note 10.1
Samsung Galaxy Note 10.1 gives multi-tasking opportunity. Others like apple's iPad also give the opportunity. What is better? Why?
Does it give pen-paper writing opportunity?
Hi There,
Samsung it is Compared to the iPad wherein users would have to double click the home button so to switch to another app; surprisingly, Samsung’s multi-tasking option is a computer-like.
Multiple apps can be opened into their 10-inch screen. There are also mini apps that can float somewhere in the screen.
Yes, it also has a pen-writing tool matched with the app.
Here are the specs of the Apple iPad and the Samsung Galaxy Note 10.1 then check which one is better. The Apple iPad 1 has 2 versions: Apple iPad Wi-Fi, and Apple iPad Wi-Fi with 3G. The one I will describe is the latter. The Apple iPad Wi-Fi + 3G has no voice communication support meaning you cannot make any voice calls.
It is a 3G device that operates on 2G and 3G bands using GSM and HSPA technologies. It was unveiled on January 2010 and released on March 2010. It measures 242.8 x 189.7 x 13.4 millimeters and weighs 730 grams. It uses a micro-SIM card. It has an LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 768 x 1024 pixels screen resolution.
It supports multi-touch and protected by a scratch-resistant glass with oleophobic coating. It runs on iOS 4 upgradable to iOS 5.1.1 powered by Apple A4 chipset, 1 GHz Cortex-A8 processor, and PowerVR SGX535 GPU. It doesn’t support microSD. It runs on 256 MB RAM with internal storage available in capacities: 16 GB, 32 GB, and 64 GB. The device doesn’t have a camera.
It has Bluetooth 2.1 with A2DP and EDR, GPS with A-GPS, Wi-Fi 802.11 a/b/g/n with dual-band, and USB 2.0. It has built-in compass and accelerometer sensors. The pre-installed browser supports HTML. It doesn’t support Java. It runs on Non-removable Li-Po 6600 mAh battery (24.8 Wh).
The Samsung Galaxy Note 10.1 is a 4G device that operates on 2G, 3G, and 4G bands and uses GSM, HSPA, and LTE technologies. It was announced on September 2013 and released on October 2013. It measures 243.1 x 171.4 x 7.9 millimeters and weighs 547 grams. It uses a micro-SIM card with S Pen stylus. It has a super clear LCD capacitive touchscreen display with 16M colors at 2560 x 1600 pixels screen resolution.
It supports multi-touch up to 10 fingers with Samsung TouchWiz UI support. It runs on Android 4.3 Jelly Bean upgradable to Android 4.4.2 KitKat powered by Qualcomm Snapdragon 800 chipset, quad core 2.3 GHz Krait 400 processor, and Adreno 330 GPU. It supports microSD upgradable up to 64 GB. It runs on 3 GB RAM with internal storage available in capacities: 16 GB, 32 GB, and 64 GB.
The primary camera supports 8 megapixels at 3264 x 2448 pixels with LED flash and autofocus. The camera supports face and smile detection, and geo-tagging. The camera can record video in 1080p at 60 fps. The secondary camera supports 2 megapixels and can record video in 1080p at 30 fps. It has Bluetooth 4.0 with A2DP; GPS with A-GPS and GLONASS; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot; and microUSB 2.0 (MHL TV-out) with USB Host.
It has built-in accelerometer, compass, proximity, and gyro sensors. The pre-installed browser supports HTML5. It doesn’t support Java. It runs on Non-removable Li-Po 8220 mAh battery with standby time up to 2230 hours and talk time up to 10 hours on 2G and 49 hours on 3G.
