I just downloaded the free version of Multiboot Active Boot Disk Suite to recover a lost partition and fix system management problems. I have tried the program but it says it cannot recover the lost partition. Would the licensed version yield the same results? I'm on Windows XP 64 bit. Thanks.
Multiboot active boot disk suite cannot recover partition
Hello Brinkley,
The trial and the licensed version of any software has the same function. The only difference is that trial version has it's expiration date while licensed version has not. If the trial version is not expired then the function of the software will be successful. If your using a trial version which is not expired yet, then the problem is in your storage device. I mean that your storage device is failing because of virii, power failures, or probably several other actions.
