Multiple FaceBook account login question
Can I login multiple Facebook accounts at a time using Mozilla Firefox? I know how to login two accounts at the same time by using Private Browsing way but I also need to know if I can login 3 or more accounts at the same time.
Best Answer by mamuncse
Answered By 10 points N/A #119306
You can open multiple accounts by opening it in incognito window. Go to your toolbar button which is on the right of your navigation bar and click the tab where it express new incognito window or you can also activate it by pressing  “Control” Key+”Shift” Key+”N” Key.  By doing this, you can open multiple face book accounts in Firefox.
Answered By 0 points N/A #119307
If you have more than one Facebook account, you might have tried lo login into them at same time. Yes, I am talking about way to login multiple Facebook accounts simultaneously. If you are using Mozilla Firefox browser, you can easily do it.
Login Multiple Facebook Accounts On Firefox
STEP 1: Right click on the shortcut of Firefox web browser and click on Properties.
STEP 2: Now, at the end of Firefox Target, you need to add the below code at the end of the path,
For example, C:Program FilesMozilla Firefoxfirefox.exe” -profilemanager -no-remote
STEP 3: Now when you open the Firefox, you would find a new box. And there you could to login multiple Facebook Accounts.
NOTE: Multi-Fox Addon is a Firefox add-on which lets you log into more than one Facebook accounts. Its worth trying, if you not prefer tweaking its settings.
Login Multiple Facebook Accounts On Chrome
If you are using Facebook on Chrome, the only way to login multiple Facebook accounts, then you can do it by operating in Incognito mode.
So just by hitting Ctrl + Shift + N, you can launch Incognito browser where you can login to another Facebook account.
Happy Facebooking!
Answered By 10 points N/A #119308
Thanks Mamuncse! Your solution really helped me. Thank you for the steps you gave. Many thanks TechyV!
