sirazhoque
Posted on - 09/22/2011
I have to do a lot of works with both Windows and Linux OS. Can any one help me suggesting the correct way of installing both OS in same PC? How should I install Linux without using virtual machine? I have HDD: 500GB, RAM: 2GB, Processor: 2.84GHz.
lokim
Multiple OS in same PC
You can install windows operating system with Linux operating system by using different partitions.
You hard disk is enough to install both operating systems. so you can do it as follows.
First of all you need to install windows 7 ( my preferred method ) or you can install Linux first. in here i will not go for more details just follow below link and you will learn how to install both Linux and windows as dual boot.
If you have any doubts please post a reply
Thanks
How to install win 7 and Linux step by step
Go through it and you will learn everything that you want to install windows and Linux
