Multiple Remore conncetion via Team viewer
Is it possible to connect more than 2 computers in team viewer and establish a VPN that can enable secure sharing of files and data? what is the software equivalent that can match team viewer in terms of network diagnosis remotely? how can I get to install team viwer on a mac machine?
Answered By 0 points N/A #192913
It is possible to establish a connection between several users using Team Viewer. Once you install team viewer and open it, there is option of acceptance of networks under options tab.
There are multiple software’s for Remote connections/file sharing. One of most useful and user friendly tool is “Ammyy Admin”. It is easy to install and use. Only for file sharing with multiple users, you can use Sendspace online site. It is also easy to use.
To install Team Viewer on Mac
1. Download a host file of team viewer on your system.
2. Once you download it, install it.
3. Once you install it, drag the icon of team viewer to applications folder.
4. In this way, the team viewer will get installed on your Mac.
