MultiStarOrbiter – Unhandled exception has occurred in your application
Hi guys,
I wanted to get a vast Orbiter adding Multi-Star system to it. I think it a very hopeful assignment for the Orbiter. However, I faced a problem while adding solar systems. Have a look at the screenshot below. How can I get a remedy of this issue?
Please help.
MultiStarOrbiter
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Input string was not in a correct format. Couldn't store <3.02308479737938> in LongAscNode Column. Expected type is Double.
