Hello guys, I have an error regarding to my music player in my Ubuntu.
I update my music player, and after update I got this error. I think updating player should give a good performance than giving this kind of error.
Do I need to update again my music player?
Or do I really need to re-install my music player?
Please help.
Thanks
Error
Credentials not satisfied
Martin00
Music Library- Credentials not satisfied
I think this error happens due to some problem in music player library. Might be due to some reason of that you update the version, but not integrating the music player libraries with the application. i suggest you to re-install the music player. I have also using Ubuntu operating system. many application error occurs after updating the version but re-installing it will solve the problem.
Good performance can obtained by just decreasing the load on your computer RAM because the most programs you run on the same time will always make heavy your computer. just clean u the caches and than try your music player to run if it does not work than re-install the music player again.
