Music player in my Apple mobile phone having a problem please help.
The music player on my Apple mobile phone seems to be having a problem because it only plays a couple of songs, which then I would have to manually access to continue playing the following tracks in my playlist. I thought at first that the software I was using was the one that had problems but when I used another application, it seemed to have the same problem. What can I do to resolve this?
Answered By 80 points N/A #109351
Hi Elvin,
I think you need to update your ITunes and apple mobile software. I already encountered that kind of problem and all I did is updated the software/application that I am using and it all went right. You should also know that apply has released a troubleshooting guide which is very helpful to their users if they have encountered such problems.
To know more about what I'm talking about, just visit the link below and read carefully. It might help you a lot. Make sure that you go to the section where you can find the method. But I am very sure that using the solution that I have mentioned will help you.
Download Link
