Musicians template joomla needed urgently?
Good Morning Everyone
I am planning to develop music related website. For this purpose, I need a Joomla music template. The template should work with Internet explorer version 7 and above, Mozilla firefox browser version 1 and above.
Other options like choosing different background styles, selecting different header colors should be there in a template. Anyone tell me free musicians template joomla.
Thanks in advance.
Best Answer by Drake Vivian
Answered By 0 points N/A #187603
Hello, Charles!
This template is available. You can search it for internet as well as many forms are also available tutorial for you.  Whatever, I can assist you by informing this http://www.designfloat.com/blog/2011/11/16/free-joomla-music-templates/  website which provides different types of musical templates or Joomla users.  You can try this. If there is any problem later, please don't feel shy to knock me!
Answered By 30 points N/A #187604
Hi there Charles Marry,
Searching the Google using the “Joomla music template” will give you plenty of results to choose from, so that is where you should start.
I don’t know what genre your website is going to be about, so I’ll suggest you a few classic ones that are easily customizable and could fit your needs.
Gavick is offering a free music template for Joomla. It is light, modern and responsive so you should definitely try it: https://www.joomlashine.com/music-joomla-templates.html
There is one really nice one on the themza.com (http://www.themza.com/joomla1.5/feel-the-music-template.html) called Feel The Music, if you are looking for something dark.
Also, make sure you visit the joomla24.com, as you will find plenty of free templates there that could fit your needs.
Best regards,
Drake Vivian
