During installation of a MuVo Vidz under Windows XP and when I have selected the option of USB Device Driver for installation, I have encountered this error message which I can’t resolve without expert’s advice. Any help would be really appreciated.
Error Message: Target system OS not supported.
MuVo VIDZ application Installation error
Hi Thomas,
This is a perfectly alright error message and is expected if you are trying to use the option of USB Device Driver for installation on any OS other than Windows 98 SE.
In other words, you need not install the USB Device if you are running any of Windows ME, Windows 2000, Windows XP.
For these operating systems, you only need to install the MuVo Vidz application.
Hope this helps you understand the cause and the solution.
Mclean Buono
