MW3 Playing in Cloud Storage Error
Hi!
I was playing MW3 in the Cloud Storage and it keeps giving me the error message status: code 80004004.
What seems to be the problem? What is the best thing to do that you can suggest me?
Should I just save my game on my computer?
Answered By 590495 points N/A #154583
I think this problem that is happening while you are playing something through cloud storage has something to do with your current internet speed. If this is the first time you encounter this problem, try restarting your machine then try it again. If it still doesn’t work, try checking the stability of your current connection. Your connection probably is constantly having an interruption or sudden slow downs in the speed. Check your internet connection by visiting some web sites using any of your web browsers. Try watching some streaming videos to see if the video will buffer up fast. I’m sure you will notice it while the video is playing.
If you experience sudden slow down on the speed, maybe it’s because of the heavy congestion in the network traffic. You should try playing again some other time or try it during off-peak hours so that the network is not heavily congested.
