Mx One Manager Provisioning User Benefits
I was thinking to use mx one manager provisioning for my business but I am not aware of its benefits. Will it be proved as useful for me? Can you please tell some of the user benefits of the same?
Manage one or more positions at the same time. Print the configuration for one or more instances. Tasks such as users, extensions, subsystems, administrators, and security profiles. The database comparison makes it possible to identify the differences can lead to malfunctions. View the details of multiple databases on the same page for a single. Overview of the current configuration.
Use extension models to reduce the number of extensions. Set up fields. Models can be shared with other MX-ONEs. Provisioning Manager applications. Online help with the user manual, help with tasks and single field help. A sitemap gives you an overview and direct access to all Tasks. In the task orientation, all with the Tasks are collected on the same page. Easy to understand error messages.
These are some of the user benefits I am aware of. Hope it helps!
Notifications
