My 3DMark has encountered a problem
Hi guys,
My 3DMark has encountered a problem. The screenshot of the error message is as under. I tried several ways to get a solution of this problem but failed. I uninstalled the program and installed it again. Could you please help me to solve this problem?
Thanks in advance.
3DMark11.exe-.NET Framework Initialization Error
To run this application, you first must install one of the following versions of the .NET Framework:
v4.0.20926
Contact your application publisher for instructions about obtaining the appropriate version of the .NET Framework.
