My account on YahooMail has gone.
Why it is my account in yahoo mail is gone? Is it necessary to be active? What are the possible reasons why I cannot log-in? It says “forgot password” besides I log-in the right email add and password.
Are you really sure that it is the correct password and email add? For registering yahoo mail account, one needs to have an alternative email where the details of your yahoo account will be sent including the email add itself and the password. Have you checked it there? If so and still the problem persists, you can use the Forgot Password option below the Password textbox.
Be reminded though that your password will be automatically changed, but you can still change it back to your old password once you have opened your account. If nothing helps, report it to Yahoo!'s customer support for help.
Hope this helps!
Try to check again your username and password. If it doesn't work try using other keyboard. This may sound a bit odd, but maybe there are keys in your keyboard that is required on your password that are not working. Check it just to be sure. If it still doesn't work try to visit Yahoo Password Helper.
Hope this helps.
