My Acer Aspire Setup Is Starting Services Are Stuck In The Middle Of A Process
How to fix the Acer aspire setup is starting services of the computer? Discuss the error occurrence in detail.
While using my Acer aspire computer screen went black, and it shut-down. Then, after restarting the computer, it goes from home-screen to ‘setup starting service.’ It sometimes throws an error mentioning that ‘the computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click “OK” to restart the computer, and then restart the installation.’
The fixing instruction is as follows:
Step 1: Power on the system.
Step 2: Hold the “Alt” key and press the “F10” key to start Acer eRecovery at the white BIOS screen.
Step 3: Click on ‘Restore to Factory Default Settings.’
Step 4: Click on OK to continue the process.
Step 5: This will update all the eRecovery data and reset all the settings by removing the corrupted file.
Step 6: Once all the process finishes then click on “OK” to reboot.
