My android button software is not working.
Hi guys,
I've downloaded an android button software but it is not working on my Samsung galaxy Y. Any of you used android button software on your galaxy Y? Which one?
Hi guys,
Hello Aldo,
I am going to write down the solution of button software for your  phone which having the Android OS. Solution:
It opens the website which having this free application. You can download it install it free on your mobile.
Harthy Opera
Hi Aldo,Â
There seems to be some problem with your phone.
I'd recommended you to restore your phone to factory default settings. Make sure you do a back-up of all the necessary things. This would take your phone to an out-of-the box state – same as what it was while taking it out of the box.
You can refer your phone manual to restore your phone to factory default settings.
Hope this helped!
Drianna allen
