My Android Phone Is Showing ‘acore Has Stopped.’
How to fix the process android process acore has stopped error? What are the reasons behind the occurrence of the error code?
Contact app data error, System apps disabled or deleted by mistake, installing custom ROM, virus attack, and error while upgrading OS are the reason behind the occurrence of the acore has stopped error code. The methods to resolve the error code are as follows:
Method 1: Contacts
Go to Settings >> Applications Manager >> Contacts >> Storage >> Clear data, then tap on the Clear cache. Switch off the mobile for few minutes then restart the device.
Method 2: Factory Reset
Go to Settings >> Back up and reset and select Factory Reset. This will reset all the settings and clear all the corrupted data from the phone.
Notifications
