My antivirus software not work properly
I use avast antivirus software as my security software.
But it not catch viruses in my computer. I have lots of viruses in my pc.
I updated it and it doesn't work.
How can I get rid of those viruses?
If its a license one, then read this otherwise don't even bother if its only an infiltrated version or with a fake serial key. Because it might be detected by the Avast main server and disabled it because it is not a true copy. If its only a trial version, then you might want to buy a new serial key for your anti virus software. In your case, I think it catches the virus but does not delete the virus because you have a problem with your license.
If you can't buy, then its much better to reformat your operating system.
It is locked because of either of the three:
If you have the first problem then I suggest that you buy an Original Copy or just purchase a serial key for the said problem. It is same for the second problem and third problem just purchase serial key either by online or through a store that sells original copies of Avast.
If you really are cheap and don't want to spend to much on your computer security. Then I suggest that you just download a trial version of anti virus software like Eset Nod 32, Avira, Kaspersky, McAfee, Panda and many more. If you have an original copy of Microsoft Windows from XP SP3 to Windows 7. Then download and install Microsoft Security Essentials. It is free to download and install but will validate your copy of windows first.
Hi there,
AVAST is just a pile of JUNK. Please uninstall it immediately cause it wont do any protection to your PC.Â
