My Apple’s cloud computing application is not functioning
I just completed my confirmation with the Mac website. As far as I know, I have completed the validating process with the Mac website by confirming my email address.
Whenever I launch the cloud computing software, it says that I have not completed validating process yet, and after a while of ā€œloadingā€, the application crashes and exits and I am redirected to the main screen.
I attempted countless times to the point that I even removed my account, but the application still crashes.
What should I do to prevent the application from crashing?
Thank you for the help.
Answered By 590495 points N/A #109852
If the installed cloud computing application on your computer behaves like this, always crashes and terminates itself automatically every time you launch it, maybe the problem here is with your computer. If you already confirmed your email with the Mac website, then the registration was complete already.
You need to check your hard drive for any possible errors.
Maybe this is what causing the unusual behavior of the cloud computing software. If you have a disk utility application installed on your computer, use it to diagnose your system.
Otherwise, use Windows’ own disk check tool or just follow the instruction below:
  1. Right-click on drive C and then select Properties.
  2. Click Tools tab.
  3. Click Check Now.
  4. Check Automatically fix file system errors and then click Start.
If the problem didn’t change after checking your computer try uninstalling and reinstalling the application.
