Applications cannot be opened Error oleacc.dll missing
Oleacc.dll errors are caused by corruption or removal of the oleacc DLL file. It can also be a case of registry problem, hardware failure or malware and viruses.
Hope this Helps. Thanks.
It look's like you have some windows error and it is causing problem in your PC. To solve your problem you can see for any previous updates and any changes you make to your computer earlier and try to solve these problems.
If you have make some registry change in your computer then you can see that you have not deleted some registry files or some windows files form your PC and now your window is being corrupt also check for any virus in your computer that is infecting your system files and run a full virus scan to your computer and make sure that you have a valid updated virus scan software installed and it is working properly.
After you have check all of these then make sure that you have no hardware problem such as your RAM is missing or it contain some error and try to resolve this problem by checking the hardware of your PC. You can install a new copy of your file from internet also but it will be better if you download a original file from your window and it is only possible if you re install your current windows.
