Hallo there!
I just realized that Autodesk login doesn't work for me. I have tried several times to use the password recovery but it is more like the button itself is deactivated for reasons not known to me.
Once I try the login attempt then no button works.
Whenever I place my mouse pointer on any link I see javascript(0) in the progress bar at the bottom.
What can I do to have myself logged in?
My AutoDesk login doesn’t work on all tested browsers?
Mostly when you need to make changes in your windows registry then it requires that you are logged in as administrator.
So log in as administrator and try to run the program.
Also check the firewall settings as it can block your program to execute. Disable it for a while and then login and you will be able to log in to Autodesk.Â
Hardford
If you are really having issues with your current usage of auto desk. You can do the following:
First you should remove all software’s, applications related to your auto desk.
Steps:
– Go to Control panel.
– Click uninstall a program
– Remove all software updates related to auto desk
– Download a new one
Here is the link
