Carey
Posted on - 11/01/2011
I am having trouble with the bandwidth that is used by an “android download manager.” I use it every time and this application exceeded its 10GB daily allocation. People have advised me to delete it but before I do that, I would like to be cautious. I would first like to know, what is happening or why this application is making all these to happen.
lee hung
75 points
My bandwidth is having issues with the android download manager
Hellom Carey,
The problem here could be that you are downloading too much and going past the allocated bandwidth, or the android download manager is taking a lot of bandwidth during the download process. If you can verify that you are downloading as usual and these problems are not related to the rate at which you are downloading the you will just have to delete the android download manager.
Delete it and get another version and install it and see if it solves the problem, because 10 GB is a lot of bandwidth to be finished that fast.
__
Regards
Lee Hung
