Adams Baker
60 points
Posted on - 10/20/2012
Hi guys,
My Banshee Media Player has encountered a problem. I received an error message while opening an mp3 file with Banshee Media Player. It requires an additional plugin. Have you any idea for the Advanced Streaming Format (ASF) demuxer? Please help.
Thanks in advance.
Banshee Media Player requires an additional plugin to decode this file
The following plugin is required:
Do you want to search for this now?
Hello Adams,
Well, it appears like there are some plugins that are required for that specific file that you are trying to open to be opened successfully, and therefore you will need to look for it and install it. Are you getting the issue while opening all media files or that specific file? Just confirm that.
Nicke
Search for the plug-in by visiting the internet and download it once you have found the specific plug-in. You will be then able to play your file you are trying to play. The other thing i will say is use another player like VLC media player to play your file.
Smith Thompson
