My Battery Icon Is Not Showing On My Windows Taskbar
We don’t pay special attention to any type of missing or error issues on our computer, for example,  charging indicator/charging symbol is missing from your computer, this might be leading to bigger problems and requires attention.
Follow these steps for the restoration:-
Go to Computer Management> Go to Device Manager>Go to Batteries Options>Go to Microsoft AC Adapter> Disable the Microsoft AC Adapter> Disable the Microsoft ACPI- Compliant control method battery>Scan for Hardware Changes>Now Enable the Microsoft AC Adapter>Enable the Microsoft ACPI
Battery Icon Not Showing on Windows Taskbar can be due to malfunction of the operating system properly or malfunction the power AC driver properly or Automatic changes on power AC driver option.
Now when you see the taskbar of your computer. You will get the battery icon. If still after all the steps the battery icon does not come to appear then restart your computer, and it will be present.
