Hallo! I am having a problem downloading music using bearshare 2011 version. It was working very well initially, but now everything seems not to work. Every time I click the download button nothing happens. I need some guidance on how to go about it. It has also refused to update. Thanks!
My bearshare 2011 has lately refused to download music?
Hi
Bearshare is good application used to download free songs online, Bearshare is not working properly, This could be due to newer version any update , Which this software is looking for, Now I am sending you a link form where you can download update for this software, Plus if the software still doesn't work then simply reinstall the software,
https://en.softonic.com/s/bearshare?redirectedFrom=app
Thanks
Hi there Susan Rozack,
I'm sorry to hear about your troubles with a BearShare. Looks like you're stuck with a quite old version that is not supported any more. In order to fix the problem you will have to manually uninstall the software and install the newer version.
Another possible problem is expired or banned user account. To resolve that you will need to contact the Customer Support Service on the BearShare website (
http://www.bearshare.com).
Best regards,
Drake Vivian
