leon-collin
Posted on - 10/01/2011
I worked previously, a copy Adobe.After.Effects.CS4.
After working a full dump of the device installed and prepared but not prepared a working download it again.
After several months of work. The program stops when it runs!!
Show me the message:
Adobe After Effects CS4
Adobe After Effects CS4 has stopped working
Windows can check online for a solution to the problem.
I tried to download the version Albrootabl to the small size I thought it could work
But after download and run the program is usually the message to appear.
My big Problem is installing Adobe After Effects CS4
Hi there,
Adobe after effect is a part of adobe Photoshop cs4. The best way to solve error is to replaces this software with its new version if available. If there is no new version available then try to install this software from other source. Download it from here https://filehippo.com/ then reinstall this driver software again.
If you have virus then remove it first. There is another reason that may be your computer is corrupted with virus. So need to use updated antivirus and scan full computer. When you have done with it then use some data recovery software for recover your lost data. Â
