My Blackberry Desktop Manager cannot install OTA
Hi Experts,
My Blackberry Desktop Manager cannot install OTA. Mentionable that I installed earlier the same and also uninstalled it. Now it is showing the error message as under. I only selected .alx file. Please help to solve it.
Thanks in advance.
Applications
There was an error importing files.
No additional applications can be found. Your file might contain applications that already exist in the Application list. are not compatible for your device. or have errors.
Answered By 0 points N/A #191853
The error was produced while syncing your Blackberry and your Blackberry manager over the air (OTA). While your blackberry is syncing it was interrupted and that causes the error. I suggest try re-syncing your blackberry and your machine. Some applications can be corrupted when interrupted during the syncing of the two devices. If you have already application on your blackberry application manager and you want to sync it to a different blackberry phone there is a chance that the application is not compatible with the blackberry phone.
