markkent
Posted on - 09/26/2011
Hi! I have a blackberry curve that was working fine. I accidentally dropped it and now it powered ON but the screen doesn't come up with anything. I tried removing the battery and leaving it OFF for a few minutes but when I powered it On its still not working. Is there anything simple I can do to fix it?
My blackberry won’t display after I accidentally dropped it.
Well as concerning with the problem you are currently facing is that your screen of black berry curve is crashed from inside this is the reason of turning on but showing nothing. You have to take your mobile to nearest mobile repairing center where they fix both hardware & software problems. First of all try to update your mobile’s software it may fix your screen issue if it is due to software crashing, but if it doesn’t fix than you need to buy a new LCD for your mobile. Go to nearest mobile accessories shop and ask them to put new LCD on your mobile. If your mobile is still in warranty you can send it for claim to the company.
