I wanted to save some image from my camera Rebel EOS T3 in jpeg or RAW.
I followed necessary instructions in this regard.
I received an error message.
I do not understand the error message.
If you have any idea for the issue, please help.
Thanks in advance.
file-tiff-load.exe – Application Error
The application was unable to start correctly (0xc000007b).
Click Ok to close the application.
My camera pc suite is not running, and giving me error
This error occurs when the application has 32 bit and 64 bit dlls dependencies. Please verify that you have installed the right version for your system. For more checking you can see the system error log.
I think now you need to download the right version and install a fresh copy of it.
Thank you.
Hi Nelson Carters,
This error is caused in one way or another by misconfigured system files in your operating system.
All you have to is download this 0xc000007b repair utility here.
Install the software and scan your computer then click fix button.
