I have a wireless canon printer and this strange thing happens that whenever I give print command, it takes two pages at once, prints on one and the other comes out blank but in a rather crushed form. I can put one page at a time but I need a permanent solution to this problem.
My Canon printer is printing blank pages
This is a classical printer problem which most of the people face while printing a page. No need to put one page at a time. Make sure you do the following 2 things before you print the next time.
1. The pages often come so compressed that a 2 papers may look like one. Often due to the heat generated inside the printer for the imprint to happen, they get separated and the other paper gets crushed or is stuck inside the printer. You just have to check that the reap of paper that you put thru' the paper you shuffle from each side one by one like someone playing Poker may do so for a pack of cards.
Something like;
2. You should also check that the printer tray is exactly the size of the paper reap. This would ensure that papers are packed tightly and there is no room of diversion.
These steps would resolve your problem. Happy Printing!!!
